Dryer damaging clothes
Hello, I have a model electric dryer. The clothes seem to get caught by the drum when you open the door they are hanging or stuck, usually burned or marked by rust or even holes. From what I have read there is a seal that is suppose to go there? What steps are needed to replace this seal? The drum seems almost loose as if you open the regular door you can reach in and actually push up on the drum slightly. Thank you so much
I would say that as a first step you should replace the rear bearing. Here is the kit to do that.
AP2142648
When you do this you will have to take out the drum, and you can then see if the front felt or other parts will need replacing.
Is there a diagram or how to located on here somehwhere that shows how to replace this or do the repair? Thanks for your assistance!
