[FONT=Trebuchet MS][SIZE=3]Hi,
My Maytag dryer, DE712, runs and heats in the timed cycle only. I have checked the continuity of all sensors that I can find, and they all seem to be OK. I pulled the timer apart, and it is very simple inside, no contacts seem to be burned or pitted.
I have been told that the timer is probably the problem, but I am not so sure. With the contacts all appearing OK I suspect something else. Why would the one cycle work but the automatic sensor cycles not work if the timer was not working ? The motor seems to work, because the[/SIZE][/FONT][SIZE=3] timer will rotate the knob during the timed cycle.
It would seem as if there is something in the auto sensor side of the unit.
I would prefer an email to my personal address if possible, it is just easier to find.
Thanks, Doug [/SIZE]
