This is a appartment size washer dryer and the dryer was working just fine then the dryer stoped working at all. the washer works fine. What could it be’ how do you test for it and how do you get to what ever you are testing for. ANY HELP WOULD BE GREATLY APPRECIATED
Your model number seems odd or incomplete.
I would check the door switch first. Open the dryer door and look for the door switch. Push it in with your finger to see if you can hear it click on and off.
If you can hear it click on and off chances are the door switch is fine.
