Dryer Drum does not turn
Hi Guys,
I have a Roper dryer model number RES7646KQ2. The problem I have is that the dryer drum does not turn. If I turn it manually it turns but with some effort. Before it would turn with little bit of effort. I ripped open the back side took the filter housing out but I don’t see any belt broken or fallen inside. I feel the belt around the drum snuggely wrapped around the drum. Any help on how to diagnose the problem would be much appreciated:) .
Also if I need a to replace the belt, then please supply me with the part number and some instruction link on how to get to it. I have opened the back panel and all but don’t seam to get and access point to the belt from behind :mad: .
Appreciate all your help.
Thank You
Javvy
We purchased a used GE Profile Dishwasher. On the bottom of it, at the back-center, is the Check Valve Assembly. This assembly includes what appear to be inlet and outlet nipples. Are there supposed to be hoses attached to these? If so, from where do the hoses originate/end?
