Dryer felt keeps wearing out
Hi all. My dryer started leaving brown marks on clothes about about 3 months ago. It also started lightly sqealing at the same time… I took it apart and found the upper felt worn out with the 3 plastic guides missing. So I replaced the upper felt… And greased the ball socket in the back and replaced belt… Well did not last long. What else could be the problem? Could the bearing support block and bearing in the rear be causing the drum to eat the felt up so quickly?? Need help fast, my fiance is mad at me cause it is ruining her good clothes… She is PO’d Bad…:rolleyes:
Yes, replace the rear drum bearing kit. Tom %url%
