dryer glides conflicting threads
In one forum Applianceman says "[FONT=Times New Roman][SIZE=3]The two white slides go in the two middle slots and the two green go on the two outside slots.
[/SIZE][/FONT]Read more: http://forum.appliancepartspros.com/dryer-repair/38865-ge-dryer-front-drum-bearing-slides-glides.html#ixzz1UpUBIpnb
In another forum sidfink43 says "The Greens go on the inside, the Whites on the outside of the Greens.
Read more: http://forum.appliancepartspros.com/dryer-repair/80743-ge-dryer-drum-bearing-glides.html#ixzz1UpUOhQEp
Who is right? I found this after I came to double check after repairing mine. I
put the green ones in the middle and the white ones on the outsides. If this is wrong I want to change it before they wear out.
— Begin quote from matcin2531;507230
Joe, I think you are saying, Sidfink43 is right and applianceman is wrong, because from either direction I look from middle is middle and outside is outside.
Matcin,
I just gave you my version of the same repair, using my terminology. Like I first said, it all depends on how you look at it.
:cool: :cool: :cool:
