Dryer quit & was very hot when it shut down. Thermal fuse was blown, so replaced & thermistor as well. Now dryer will run fine, but element is energized no matter the setting (even air only) & never cycles. I’ve tried following tips already posted, but no luck. Element is not grounded & thermostat trips when heat applied. Would sure appreciate any advice.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MED9700SB0
Sounds like a problem on the control board.
You could unplug the unit and check across the heater relay contacts at the board with a mete If it is 0 ohms then the relay contacts are welded together.
Then it is either replace the board or tthe relay on the board.
If the contacts are open then the problem is likely with the electronics that control the relay. Then you will have to try a new board.
Note that if purchsed from AppliancePartsPros you should be able to return it if it does not fix your problem. See their return policy.
Denman, thanks for the reply. I checked the relay & got 00 ohms on my meter. So, this likely means contacts are welded together? Can i replace just the relay w/o having to replace entire board? Thanks in advance.
Yes I would agree with that.
[COLOR="Blue"]
Can i replace just the relay w/o having to replace entire board?[/COLOR]
All depends.
Manufacturers do not publish schematics or sell replacement board parts.
So you have to get a number off the relay and then try to find a replacement relay. Try electronics supply houses like Digikey etc.
Then you need some experience with soldering, solder and a soldering iron/gun.
Solder wick or a solder sucker will make getting the old relay off easier.
Or getting a friend who has all the above to do it is even easier.
You cuold try popping the plastic cover off of the relay and separating then cleaning the contacts but in my experience this is just a temporary fix as they will pitt and weld together again.
