The dryer is blowing the thermal cut out fuse on the heating element cage.
The first replacement lasted 20 loads the second only 1.
After the last one blew I have removed the lint chute and pulled a couple of handfuls of lint from the blower wheel area with no noticeable increase in air flow. I have also bypassed the thermal fuse and get a reading of ~155 degrees from the exhaust of the dryer. The thermal fuse is open, and so is the heater thermostat (ring around operating thermostat?) but the high limit and operating thermostat have continuity. The heater element has resistance within spec and is not short to the case.
Is there a anyway to test the heater thermostat or operating thermostat.
The vent is not obstructed. I have tested the operating Thermostat by using a hair dryer. It appears to open at 155 and close at 120. I have also bypassed the operating thermostat and was able to get the high limit thermostat to open so I know that it is functional too. I also pulled the element and it looks good (no breaks, no sag).
Is it possible that the blower is not drawing enough air through the drum and is there a test. The current exhaust feels pretty strong and the three flaps on the outside vent open up. I found a test for the exhaust. I took a 2"x2" piece of paper and placed it in the dryer. I let it run and when I opened the door the paper was on the vent.
I don’t really want to put another fuse in until I know for sure what is causing the problem. I have pulled the element and it looks good. I also ran the machine with the element housing laying on the ground to see if it shorts when heated and it appeared good. I am thinking about putting a thermometer in where the thermal cutout fuse goes and trying to measure the temperature to see if clearing the lint was the problem. I don’t think so since I can’t tell any difference in air pressure coming out the vent.
Could it be a timer issue. I have been running a few loads through trying to figure it out and have noticed that the AUTO setting does not move that quickly. The timed mode works fine and I am running a Knits load now.
I really like denmans idea. Put another fuse in, and run the dryer with a no heat setting, and see if it blows. If it does it is the motor. Other then the element it is the highest drawing amperage in the unit. Tom http://www.applianceeducator.com
