Dryer is not heating keep getting a code "he"
The dryer is running fine but when it is on sensor dry it stops in a few minutes and a code comes up "he". When I put it on time dry it will keep on going but does not get hot.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDE9700AYW
Here is the tech sheet
[http://www.servicematters.com/maytag_library/docs/TDL-0141-B.pdf](http://www.servicematters.com/maytag_library/docs/16026116.pdf"]http://www.servicematters.com/maytag_library/docs/16026116.pdf[/URL]
Has info on your "he" error.
Here is the manual
http://www.servicematters.com/maytag_library/docs/16025911.pdf
And bulletins which may be applicable
http://www.servicematters.com/maytag_library/docs/TDL-0132-B.pdf
[URL="http://www.servicematters.com/maytag_library/docs/TDL-0141-B.pdf)
