[SIZE=4]Dryer was found with very hot clothes and hot dryer! I have checked the exhaust and lint holder which are clear. After reading threads[/SIZE] [SIZE=4]is the "cycling thermostat" the first thing to change? Thanks for any help you can give.[/SIZE]
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LEC6848AQ1
See the attachment for the wiring diagram.
First I would check the heating element.
Check the heating coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high.
Next I would check the internal heating element in the cycling thermostat (thermostat heater in the wiring diagram.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Thanks Denman for all your help. Replaced the Cycling Thermastat which fixed the problem
