My dryer had stopped working, the motor will run but the drum would not turn. I opened it up and saw that the belt was lose but not broken it had come off the pulley and the spring was dangling lose. I reset the belt and re-hooked the spring. the dryer seemed to work again. I then put towels in the dryer and it would not turn again so I took a few out and left 4 in there, it will turn but does not seem like its turning like it should. Is this a sign of a bad belt that needs to be replaced or is it something else?
Related topics
Drum/Tumbler Won't Turn when Dryer's Running | 1 | 1726 | April 1, 2012 | |
Frigidare Dryer Spin Not Continous | 0 | 1037 | January 9, 2011 | |
Replaceing Belt | 3 | 1433 | September 1, 2008 | |
dryer wont turn | 2 | 1591 | February 2, 2010 | |
Dryer turns on but won't turn/drum seems loose | 4 | 3300 | August 8, 2009 |
