Kenmore dryer keeps running & does not shut off except when door opens. heat is working & timer works & keeps going past both the timed & automatic off settings. what’s going on?
Hello.
Most likely the problem is bad timer. If there is no resistor at the timer - replace it.
The timer AP3100522
Post the results. Thank you.
