IDryer motor bearings are shot, bought a new motor at AppliancePartsPros.com, cannot remove the old motor, completely stymied!
Put vice grips on the end of the fan by the motor and a pipe wrench on the pulley side and just slam the pipe wrench clockwise; burning/overheating bearings will freeze the wheel to the motor shaft. I find this works without busting the blower.Use a long heavy screwdriver to pry the c clamps off the motor, saves on the knuckles.
Thank you!!
Hey Padme…remove the snap ring from the motor shaft that holds the blower in place. Also, remove any covers, shields etc, that is in the way.Afer that, remove the saddle clamps that hold the motor in place. Refer to the pictures breakdown for your model. good luck…wrench:)
Kitchenaid Superba (Gas Range)
Electric Display ‘beeps’ and ‘Electric Probe’ icon flashes. I do not know how to stop it. I do not have a probe nor a users manual. So, two questions … how do I get the ‘Users Manual’ and how do I get rid of the beeping. It is very hot and humid in Florida right now … could there be condensation or accumulated dirt in probe entry that is short circuting???
we got the same problem have you fix it already , what did you do , did you replace the module or switch…thanks
