My Whirlpool Dryer (Model # LGR8858EQ2) starts up and runs fine, but doesn’t heat/dry the clothes. It is more than 10 years old. I clean the dryer lint before every load.
Any advice to check for (and fix) common problems by myself will be greatly appreciated!!
You may want to start the troubleshooting from checking for continuity the thermal fuse (#7 at the [B]diagram[/B]).
- The thermal fuse 3392519
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=246761
