Dryer will heat up in automatic dry mode but will not heat up when on Timed dry mode. What is causing this?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=WED5100VQ1
The most likely culprit is the timer.
This can be checked by unplugging the unit.
Put it to the timed dry and check across A to B.
It should be 0 ohms.
Be sure to disconnect the wires either from A or B. This prevents you from reading an alternate/parallel circuit path.
