hi there. sorry I was so light on the particulars on the last post
I found the correct model number
When I set the temperature to delicate and the timer to a full cycle on delicate the drum turns good but I do not get any heat.
When I set the temperature to normal and the timer to full normal cycle the drum turns and I get heat however it is hard for me to tell if it is full heat
I hope this helps
rob
