Hi- The power went out a few days ago. When loaded the dryer today it starts and then stops after a matter of seconds or a minute. Several of the lights flahs and move around: while the "regular" light is lit the "off" light will flash, and then not flash. Start stop. Start stop. Could this be the Control Panel or something else? This machine has had the control panel replaced twice before, once under warranty the others out of pocket. Ouch!
The machine is not quite 6 years old.
Could it be something else or should I just order a new control panel (again)?
Thanks!
CAZ
