I need to know what part I need to repair this model dryer. The dryer will heat up for a few minutes and then stop heat and will not dry the clothes. I need to know if it is the element ofr something else.
Thanks,
Kris Allen
Thanks,
Kris Allen
Kris,
The first thing I would do is make sure the dryer vent line is clean all the way through its outlet. Remove the rear panel. Remove the lint chute (#1 on the diagram) and clean it inside.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=245746
