MY DRYER RUNS BUT DOES NOT HEAT UP WHAT COULD BE THE PROBLEM?
My Dryer Runs But Does Not Heat Up What Could Be The Problem?
For a dryer, you will need a meter to check things, rather hard without one.
SHU 4302UC/U06 DW with a leak apparently coming from the vent area of the soap dispenser. Water drip forms inside the plastic housing and drips from the bottom onto door insulations and then to floor. This picture was take with the outer door removed. See attached image , any solutions?
Thanks in advance, B
