does anyone know how to get the front off a dryer. it only has 2 clips on the bottom and 2 screws in the mid next o the lint trap. all are off and it wont come out
Hi Keith
I cannot get your model number to come up, but you can look at the dryer and you will see a gap between the top and the front. Insert a putty knife or flat blade screw drive at each end and you should be able to release a clip which will allow the top to flip up. You can then remove the front.
Good luck, let us know if you need further help
