My admiral Dryer stopped mid cycle and there is no response the timer is still ticking but the internal light doesn’t come on when door is open and i have proper voltage into and leaving timer and at the door switch it ohms out as good also, is ther a fuse or switch in line somewhere on this model if so where would it be located. Thanks for any helpful info
Thanks for the info about my dryer i did find the thermal fuse link to be bad meaning no continuity it took about 30 minutes to get the dryer apart to find it because there was no detail drawing on its location but it was mounted to the heater element box that is behind the drum. So the part is on order and we should be up and running soon. Thanks again:)
Sweet thanks for this thread. I knew the fuse was bad on my dryer cause i read the print that was taped up behind the control panel and thats the only thing I could see that could be wrong. but until I found this page I had no idea where the fuse was lol. Good thing I now feel stupid nowing its right in plain view and easily accessable lol. either way your site seems to be the cheapest for this so I just ordered one :D. Sorry for bringing back a 2 yr old thread but I was excited to find something about my 8 yr old dryer.
