The dryerruns and drys clothes but it does not shut off the timer does not time out in addition i changed the timerput new one in no results still runs but does not shut off ?
Here are your parts includes a wiring diagram.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=mde8400ayw
By "timer does not time out" I am assuming you mean that it does not advance.
Does it not advance in both timed dry and auto modes?
If it is OK in timed dry, have you cleaned your moisture sensor bar (Item 6 in Section 8). If there is any dirt etc between the bars the unit will think the clothes are still wet and will not advance the timer.
