Dryer squealing
My dryer still works fine other than a loud squealing while running.
Took it apart and the front glides are bad, but if turn the drum by hand still squeals, so assume the rollers need replaced. Anything else I should be looking at. It’s been a good dryer hate to buy new if can be fixed at resonable price. Thank You in advance.
Thank you. I still had it apart when I was turning by hand. Took the drum out and one of the rear support rollers turned easy other you could barely turn. Have ordered the new parts, so will keep my fingers crossed.
Thank you very much.
