This is a double stacked unit and the dryer has an ear splitting squeal to it. This must be a bearing or bushing. How can I get an exploded parts diagram?
See if this doesn’t help you.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/5995519542.pdf
You can also see an exploded view of your machine by clicking on the model number and APP will give you much the same as the above site.
Good luck.
I think the drum support bearing will do the trick, it almost always does. Don’t think the belt is a problem and you can certainly lubricate the idler wheel while you are in there (be careful not to get any lubricant on anything). Also, take the opportunity to thoroughly clean, particularly the vent system.
Good luck, and keep us informed.
how do i test the motor by its self to see if it is good, like where would i connect meter leads, and where would i connect meter leads on the board to see if the board is malfunctioning
