Dryer stopped in mid cycle. When the door was open there was no light. It smelled like it was hot. The breaker was checked and there is power to where it is plugged in. HELP!!
Thanks,
Melissa
Thanks,
Melissa
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=PYET4444AYW
Sounds like the thermal fuse has blown, Item 5 Section 4
Note that it comes with a hi-limit thermostat so both the fuse and the hi-limit should be replaced. The high limit should regulate the temperature and the thermal fuse should not blow unless there is a problem with it or a grounded element.
Also check the following before replacing the fuse:
