Dryer stops after 5 minutes
Dryer operates normally for five to seven minutes then shuts off. Restarts immediately as soon as the start botton is pushed. Will run for five to seven minutes and it turns off again. Replaced the control board, problem persists.
Does it do the same when set to air fluff?
Eric
I didn’t try it on any other settings. In hindsight I suppose that would have told me something. I’ll put it back together on Monday and check it out.
