Dryer stops spinning
We just replaced the bearing on the back of the drum last week because the dryer was grinding loudly. After putting it all back together it only runs for about 3 minutes then the drum starts slowing down and comes to a stop. The belts appear to be OK. After it stops the dryer still hums and sounds like it is running.
Did we miss something while putting it back together or could the motor be going?
Thanks,
Amy
