Dryer Takes Too Long...
The dryer vent is clear, the lint screen is clean, the heating element works, but the dryer still takes 2 cycles to dry. Is it possible that the element can degrade over time meaning that it still heats just not as well? I was going to replace it but dont want to waste $53.00. I have also read that maybe the thermostats can be bad.
Thanks for the help.
David
The dryer vents good meaning there is plenty of air flow. I can take it apart and look at the fan but there is plenty of air flow. could there be a blockage before the fan maybe causing it to have good air flow but not venting the dryer?
David,
What is the complete model number of the dryer?
When I Go To Start The Dishwasher, I Have To Turn The Timer Button About 4 Or 5 Times Before It Will Turn The Water On. I Was Wondering If It Sounds Like It Could Be The Timer Switch That Is Causing The Problem. Thanking You In Advance, Robert Weaver
