Dryer Tumbles but No Heat
Ok I have checked the following:
Outlet: 243V
Heating Element: 11.2 ohms, 0V
Control Thermistor: 9.6 kohm, 2V when running. Bypassed throws error and no start.
Thermal Limiter: 0.6 ohms, 0V
Motor Runs
High Limit Thermostat: 0.6 ohms, 0V, bypassed No heat
I keep hearing about a thermal fuse but I don’t see it on the diagram or visibly unless it has a different name and is one of the above.
I’m not sure what I’m missing hear. The dryer is a 2005 and very clean. The heating issue didn’t just gradually get cooler it stopped all of the sudden.
I am attaching the wiring diagram with values written in where I have tested.
I really appreciate any help…
Did you check for 240v at the wall outlet, or where the plug connects to the dryer?
You may have a loose connection at the terminal block at the dryer. Check the red and black wires to make sure they are screwed in tight
Yeah, I’ve checked the voltage at the wall outlet and it measure 243V.
I’m getting 243V coming into the dryer as well. I checked those wires and the white wire is attached to the case as it should be.
Ok, I’m not at home but will be in about a hour and a half… 5PM Central. I’ll check this then.
Curtis
If the voltages check out ok at the terminal block, go to the motor and with a screwdriver, work the centrifugal switch back and forth a few times with the dryer unplugged
checked the terminal block and had 122V white + black, white + red, and 245V red + black
Also, I don’t know what the centrifugal switch looks like but my grandparents who gave me the dryer say its still under a service warranty so I’m checking on that.
The whirlpool duet wont turn on. Power okay. Microcomputer replaced and still wont turn on. Help 3 little kids need washer.
You need to add a Model Number.
There are a number of different Duets
Also you are in the wrong forum, this is one is for dishwashers.
You will still probably get a reply but have a better chance in the "Washer Repair" forum
Also add any other symptoms re:
Is the unit totally dead? (no lights, no nothin)
Does it do anything?
Does it make any noise at all?
Was any diagnostics done before replacing the control board?
