The dryer turns itself off within minutes when running on timed dry with heat. It used to do it when running on high heat, then on medium, now also on low. However it heats up high even on a low setting (which is fine by me, as I like to dry most of my clothes on high heat). When I start another timed drying cycle right after the dryer stopped, it starts again fine and then often stops within a minute. I can also usually just continue, although about third of the time, it won’t continue, possibly cause it is too hot (the clothes feel really hot then). I usually have to restart the dryer many times to get my clothes to dry. If I run it on ‘air only’ there is no problem - it continues to the end of cycle.
I’m guessing that I need to replace a thermostat but I’m not certain. Any input appreciated.
Lidia
