Dryer Will Not Heat, But All Parts Test OK
Fridigaire Gallery dryer stopped heating last week. Light turns on, drum turns.
Performed all suggested tests today:
  • Outlet is getting 240v,
  • Dryer is getting 240v at the power supply,
  • The thermistat’s continuity is fine (~0.07 Ω),
  • The heating coil’s continuity is fine (~20 Ω)…
What else could it be?
A model number may help others help you
http://www.appliancepartspros.com/modelnumber_locator.aspx
elements can look ok an still be nonfunctional
trace the voltage from whee i comes in the back of the dryer to the element and see where the voltage drops out, there will be your problem
