Dryer will not Heat up
[SIZE=4]Need some answers from anyone will to help. My dryer is working fine no issues contoll panel lights, drum turns and no noises. However it will NOT GET HOT. I have replaced the Heating Element and still no heat. Please help if you know any solutions.[/SIZE]
[SIZE=4][/SIZE]
[SIZE=4]Thanks[/SIZE]
Please anyone know anything or have any suggestiond for me ???
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GLEQ942CS0
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Webster/1342003e_sheet_1.pdf
First check the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Next check the hi-limit thermostat.
Should be 0 ohms.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
