I have an Amana dryer the other day we went to dry a load of clothes and pushed the start button, Nothing happened. Check the plug to make sure it was fully plugged in, still nothing. Not sure if it could be a bad start button or the switch on the door. Can you help with my problem?
A model number may help others help you.
http://www.appliancepartspros.com/modelnumber_locator.aspx
Could also be a blown thermal fuse, a power problem or a motor problem.
Have you tried slowing turning the breaker off/on, sometimes you can loose half the line without tripping the breaker?
