Dryer Will Not Start
My drier will not start. The light comes on and the door switch is good. This is the second time this has happened. The first time I turned the knob a little and it started after that. This time it was running but I turned the knob to lessen the time and now it will not start. Is it possibly the timer, AP4047644? If not then what?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDE308DAYW
See the attachment for the tech sheet/wiring diagram
Here is the manual that comes up for that unit. Though it seems to mostly cover units with an electronic control perhaps it will be of some use to you.
http://appliancedigest.com/index.php?/files/file/470-16026315-maytag-amana-dryer-repair-service-manual/
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
How do you know the switch is good?
Did you check it with a meter?
Just because the light comes on does not mean that the other side of the switch (normally open) is closing.
Also on this unit the light uses the L2 side of the power while the motor uses the L1 side so I would start by checking the power.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Next I would unplug the unit and check the door switch, the thermal fuse and the push-to-start switch using a meter and ohms.
