Dryer won't continually heat
Our dryer will heat for about 5 minutes then tumbles with no heat. Timer does not move. Have replaced the 2 coils but dryer continues to do the same thing. What should I try next?
Hi,
Here is the service manual for your model dryer. In section 3 there is a troubleshooting guide that you may find helpful.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=389
Does the timer stop moving on all cycles when it stops heating?
The timer does not seem to move on any of the settings
Is one of the timer cycles a timed dry were you simple set it for a fixed amount of time or are they all automatic cycles on that model?
I have one timed cycle that can be set by a certain amount of minutes. The timer on this cycle moves, and the dryer heats unless I open the door to check it, then the dryer blows cool air until the timer shuts off. If I let the dryer set for about an hour, I can repeat the process and it heats. Any ideas?
