Dryer won’t heat so replaced heating element and still no heat is there a reset on it or is one of the sensors out that won’t let dryer heat up?because when i replaced heating element i fliped dryer forward on its front.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=wed5521sq0
First check the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts which the heater uses.
If OK
If OK
Next would be the thermal cut-off (fuse) for the heat element (Item 9 in section 3). See below MORE INFO on this.
Then the hi-limit thermostat (Item 15 in Section 3) and the main control thermostat (Item 8 in Section 3).
MORE INFO
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I beleive richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal fuse blows.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it’s contacts may not be opening (welded shut).
