This dryer all of a sudden started not heating. I have previously about 8 years ago replaced the heating element. I figured it had gone out again. I went ahead and got another one and replaced it. Still no heat. I’m wondering what I should check now to see what the problem is. Any help would be appreciated.
Eric
Hi Eric
Check to make sure you have 120v coming to each side of the connection block. The dryer will run but not heat if you have only 120v on one side.
If that is ok, check these parts for continuity. Replace both if one fails.
Finally check your operating thermostat which is on the blower cover.
That should do it.
That did it. It was the small one. I replaced both and good to go. Thanks
Great, glad you got it fixed and thanks for updating us.
