IS There a easy way to open the dryer up(front panel) to look inside
looking to see if the burner ,coil are working?
thanks:confused:
thanks:confused:
Their Should Be 2 Screws Clear At Bottom And Then Just Pull Because Theres 2 Clips In It. If It Is Gas You Should Be Able To Hear The Burner Kick On
