Dryer won't heat
The dryer runs for 10-15 minutes, then stops and the lights flash.
It does not heat at all. HELP!
What is the complete model number of the dryer?
Ae06000ces0
The model number you posted is incorrect. The closest model number I found is AEQ6000CES0.
If this is the correct model number, perform the troubleshooting as instructed in the Tech sheet and post the results.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5155893
