Dryer stopped in the beginning of the drying cycle and won’t restart. Checked fuse and it’s fine. Timer is about 2 years old.
Check for 240VAC at the power outlet.
Check the thermal fuse (5 on the [AP415996](http://c.searspartsdirect.com/lis_png/PLDM/M0512354-00005.png"break down diagram]break down diagram[/URL]) for continuity. Replace the thermal fuse and the hi-limit thermostat (#3 on the ) if it’s open.
- The part number for the thermostat kit is [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=415996&&model_id=46651&diagram_id=691706)
