few weeks ago it stopped heating. would spin, but no heat.
continuity checked out fine for thermostats and heating coil, turned out to he the control board (faulty relay)
Bought a new control board here swapped it worked great for a week.
Today the dryer shuts off 1 second after starting.
If i select "no heat" option the dryer will spin, but when i select low, med or high heat it starts, spins for 1 second and shuts off.
diagnostic error code seems to he a 95 but i cant find any info on that.
I did swap the thermister a few weeks ago as i thought that may have been the issue with it when it was not heating, so it is new… I didn’t get a continuity reading from that before.
curious what would cause that to blow?? if i have gone through 2 in a matter of weeks then i assume i have a bigger root problem.
