Dryer - Won't Start - Thermostat continuity?
GE Profile Dryer - DPSB620EC4WW - Control board comes on, can hit the Start Buttom then a ‘click’ sound and nothing. Tested continuity on all thermostats and good (WE4M300 (high temp), WE4M160 (outlet backup org), and WE4M137 (high temp). I got no continuity on the inlet control thermostat WE4M298 and ordered a new one (the new one also did not have continuity?).
No continuity on lower output thermistor (WE4M275) and also no continuity on the new inlet control thermistor. Are these supposed to have no continuity at room temp?
Also checked the door switch and the all purpose switch and those were good. HELP? Any thoughts? Control panel problem?
Many Thanks.
Both thermistors should read about 100K ohms (100,000 Ohms) at room temperature. Check the broken belt switch by the motor for continuity.
Rick,
Appreciate the Ohms guidance, both thermistors register abot 120-130,000 so should be good. I had also checked the belt switch and that is also good - shows continuity. Thoughts? Don’t know what else to check.
many thanks,
E
— Begin quote from rickgburton;779103
Use an ohmmeter to check the resistance at J2 (Motor plug) on the control board at 2A (Gray) and DS (White/Brown) wires. If the resistance is 2.5 ohms, the motor and idler switch are OK. Select "Air Dry" push the "Start" pad and check the voltage at the J2 plug 2A (Gray) and N (Yellow). You should have 120 VAC. If not, replace the board.
Thanks Rick - will give that a try. Much appreciated…
— Begin quote from rickgburton;779126
Air dry and Start voltage test checked out fine. The first one though did not show 2.5 ohms. I had checked continuity on the idler/belt switch and that was ok. I am guessing this means motor is bad?
-E
