Dry has power but won’t start. I tried jumping the door switch, changed the thermal fuse and Hi temperture, but still won’t start?? Any Idea’s…
It’s a MAGTAG Model PYE2300AYW
Here are your parts includes a wiring diagram
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=PYE2300AYW
Unplug the unit.
Set the timer to an auto dry cycle. This removes the timer motor from the circuit.
Measure from Neutral to L1 at the plug of the line cord.
It should be open (infinite ohms) or a high resistance.
Now push the start button odds are it will stay open which indicates an open in the motor circuit.
Attach/tape one meter lead to the Neutral on the line cord and leave it there.
Now work your way back through the motor’s circuit.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
