Dryer START button wont start but has power .When i push the start button the moisture sensor will light up.I also can hear the timer
Here are your parts, includes a wiring diagram.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=sde515dayw
Could be the thermal fuse (Item 4 in Section 6) is blown. It kills power to the unit.
If it is blown.
Check the heating coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal fuse blows.
The hi-limit should have regulated the temperature so the fuse did not blow.
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
Just in case it is not a grounded element.
With all the below the high limit will also have to be replaced.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it’s contacts may not be opening (welded shut)
Replaced Timer 2/2012 New Problem Washes Runs Wash Cycle When Cycle Ends To Drain Washer Stops Sounds Like Power Is Trying To Engage ? Smell Burning Coming From Control Panel Area Slap Machine On The Side Machine Will Some Times Start Up And Continue To Run And Complete The Wash.
If you are sure the timer is ok, and it probably is then either the motor or the transmission is the problem. Operate it with the front panel off and see what happens when it stops operating. I suspect the motor is turning but the transmission is not.
