Dryer
Dryer runs for a few seconds then stops. It starts to slow down then stops. It then makes a humming sounds and sounds as if something is preventing the drum from turning. If shut off right away then it will restart without waiting. Problem then repeats. If I wait to shut it off then it takes a few minutes to reset itself before starting.
I took apart the front and inspectd all the wheels and belt. Everything works find but at times it seems as the drum is sticking.
I’ll be willing to bet that the MOTOR is bad, Take the belt off, put it on AIR FLUFF and start it, If the thing quits in the same amount of time, Its the motor!!!
When put on air dry the motor works fine for a long period of time. It
You might have a shorted centrifical switch on the side of the motor,check it for burnt pins.
