maytag washer had a flood in basement about 10" of water power was on "plug in outlet not running at that time" is there a reset butten on the motor? also i replaced the original with the replasement kit that was reccumended in 01/27/09 or is there a fuse some where? note everything else works but will not spin. this is why i replaced the motor in the frist place the old motor board had a fuse on it. im willing to do the motor deal all over again if needed but id like to save $$$$
Related topics
Maytag Washer Dead | 0 | 1786 | September 22, 2011 | |
Maytag Washer 9400 top load won't start | 8 | 3189 | August 10, 2009 | |
washer motor | 1 | 777 | March 27, 2009 | |
Maytag won't work | 7 | 1795 | November 17, 2010 | |
Maytag washer filled with water then went dead | 2 | 3649 | September 23, 2009 |
