Duet Electric Dryer not getting hot
My Whirlpool Duet Dryer is not getting hot
I replaced the both the Thermal Fuse and the Thermistor, but no results
Should I replace the heater. If so how can I tell if it bad, so I don’t have to spend the $50 to get a new one
Please help…our clothes are all wet
Your model number is missing a number of digits so I cannot find the correct tech sheet/wiring diagram.
First try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heating coil requires the full 240 volts.
If this does nothing.
Measure the voltage at the plug
L1 to L2 should be 240 volts
If OK
Unplug the unit and check the wires at the unit’s terminal strip to ensure they are properly connected and none of them have burned off
If OK
Plug the unit in and check the voltage at the terminal strip. This is just in case you have a bad line cord. Be careful 240 volts is lethal.
If OK
Unplug the unit and check the heating coil and thermostats etc. for continuity.
Heating coil, should be 10 ohms approximately.
Thermostats and thermal fuse all should be 0 ohms.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
The model is GEW9200 Whirlpool Duet Dryer
Here is a tech sheet for a GEW9200LL1 which is the closest to GEW9200.
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208541833.pdf
