dmoc
January 3, 2009, 3:41pm
1
When I try starting the dryer, the sensing light comes on and there is a single beep. But it will not start. As if there is a cut off.
Is there anything I can do to find out more? Is there a diagnostic test that might give an indication?
I read where a repair technician removed the front of the dryer, vacuum’d and it then it started.
I had a large down coat with a gym shoe (to bounce and fluff the garment). That was the last thing I dried.
I hope someone can help. My email is plf999@aol.com .
I have the same problem. Both the belt and fuse are Ok. What did you find was the problem?
Found nothing yet. I relly need the help. It’s not the belt because the drum turns when I press the More time & Less time buttons. It shuts off after a short time
Ok in your initial post you said it has a single beep and doesn’t start or turn at all?..now your saying timed dry turns for awhile then shuts off?
I had to order the Control & Display Board from Sears Parts. It will take 5 - 7 work days.
