Duet won't dispense water??
I have a Duet washer that will not dispense water. The soap dispenser motor whirls along and occasionally clicks but no water. After awhile the machine shuts down with no error code- just powers down. I replaced the inlet valve and checked the pressure switch (it was good). Is it the control unit?
Hello Norwester. Make sure the wiring harness is good on the unit and the water is turned on. If so, you will need to replace the control board on the unit. AP5801469
