dyer knob does not move
[SIZE=3]The control knob on the dryer has ceased to move through the drying cycle. This happens in both the ‘Timed Dry’ cycle and the ‘Electric Sensor Dry’ cycle. As a result, the dryer does not automatically shut-off during these cycles. When the knob is manually turned to the ‘OFF’ position, the dryer shuts off. The heater does come on and clothes get dried.[/SIZE]
— Begin quote from aashish;82834
[size=3]the control knob on the dryer has ceased to move through the drying cycle. this happens in both the ‘timed dry’ cycle and the ‘electric sensor dry’ cycle. as a result, the dryer does not automatically shut-off during these cycles. when the knob is manually turned to the ‘off’ position, the dryer shuts off. the heater does come on and clothes get dried.[/size]
replace the timer. done deal!!! if you ohm out the motor on the timer, you will most liely get a reading, and be confused. replace the timer. tom
Replaced the timer, and seems to have fixed problem. Thank you very much for your help.
Good Job Asshish!!! I sometimes am a little harsh, as a technician running calls all day, I just know what to do, and don’t have to whip my meter out, and make all kinds of useless checks. To me it was cut and dry. Glad you got it handled, and thank you for letting us know. Tom http://www.applianceeducator.com
